RAP2W-G Wired Port
Hey everyone,
I've managed to configure a RAP unit to authenticate from home and extend my corporate wireless and I'm able to connect to it and receive a DHCP address. Happy days.
I've connected my laptop to the second ethernet port but I don't receive any DHCP address. The port is active in the profile with similar configuration to the wireless but no go.
Does anyone have any ideas where to start troubleshooting/rectifying this problem?
Many thanks,
Aruba
Re: RAP2W-G Wired Port
Do you see the laptop show up in the controller as a client?   What role does it have?
Check the following for the Ethernet Interface 1 Port Configuration on that particular AP Group:
  1. Wired AP Profile
    - Is it enabled?
    - What VLAN is it on?
    - What is the forwarding mode?
    - Is it trusted?
  2.  AAA Profile
    - Do you have a AAA profile defined for that port?
    - Are you authenticating that port, or do you want it open?
    - If no auth; set the initial role to something that will allow the client to get a DHCP address; and do whatever else you want it to
AMFX | ACCX | ACDX | ACMX
Retired Employee
Please check the Virtual Branch Networking VRD available at and check out page #149 to get a snapshot of the configuration required for the RAP wired port.
http://www.arubanetworks.com/pdf/technology/VBN_VRD.pdf
Hope it helps !
HT
HT
Super Contributor I
The profile hierarchy will drive you dizzy if you don’t draw it out: Assuming your ap-group: RAP, your Ether port I profile: ETH1, your ap wired profile: APWIRED.
Ap-group RAP
..…..Ethernet interface 1 port configuration ETH1
……………ap wired-ap-profile APWIRED
  • First check APWIRED, (show ap wired-ap-profile APWIRED) make sure right vlan, trunk or access port, port is trusted, and wired-ap is enable…
  • Then check your ap port profile (show ap wired-port-profile ETH1) make sure its “Wired AP profile” is correct (APWIRED in this example); to simplify, the AAA profile for wired port should be N/A.
  • Then check your ap-group (show ap-group RAP) make sure “Ethernet interface 1 port configuration” pointed to a correct profile (ETH1 in this example)
~Trinh Nguyen~
Boys Town
In response:
  1. Wired AP Profile
    - Is it enabled? Yes
    - What VLAN is it on? Our corporate data vlan
    - What is the forwarding mode? Tunnel
    - Is it trusted? No
  2.  AAA Profile
    - Do you have a AAA profile defined for that port? No
    - Are you authenticating that port, or do you want it open? Ideally Open
Going to trust the port and test it :)
Ok, so I've managed to get the wired port working now (tbh I think I just forgot to check the "Wired AP enable" checkbox.. oops
Now for a bit of tweaking. We currently use Radius to authenticate users/computers based on AD group membership. So your account and / or computer have to be in these groups to be on the wireless.
I would like to limit the wired ethernet port so that only authenticated computers have access.
I've noticed on the AP port configuration page there is a "bridge role" drop down list, is it just a case of changing this to "Trusted_computer" / "Computer" / "Staff"
