RAP3 Power connector
Does anyone know which is the part number for this?
A client lost his power cable and he wants to buy the power connector for his rap3... but im unable to find it...
Anyone?
Cheers
Carlos
Alternetworks Corp
Re: RAP3 Power connector
According to the datasheet here:  http://www.arubanetworks.com/pdf/products/DS_RAP3.pdf
Thanks for your answer Collin
that adapter looks like it is the,same fkr the rap3P which use 48V
but he got a normal rap3 which use 12V
can i use the same connector even if its a48v? When it use a 12v???
Alternetworks Corp
Valued Contributor I
There are two models of the RAP-3:
RAP-3WN
RAP-3WNP --> adds PoE out on one Eth port.
The RAP-3WN power adapter is AP-AC-UN
The RAP-3WNP power adapter is AP-AC-48V36
There is also a car adapter AP-DC-CAR
