I am trying to setup a RAP3 with a at&t aircard usb uplink. I see that the aircard is trying to negotiate the connection but isn't going through. I tried different settings from the below thread, but no luck.
http://www.airheads.eu/t5/Aruba-Instant-Cloud-Wi-Fi/Config-parameters-for-AT-amp-T-313u-on-RAP155-in-instant-mode/m-p/166272/highlight/true#M5805
Anyone else had the same problem ?
Can anyone help/ any suggestions ?
Mohit
What model is the USB device?
Sierra Wireless AirCard 313U.
The Sierra/Netgear 313U LTE modem from AT&T is natively supported on the RAP-3 beginning in 6.3.0.1 for campus RAP deployments and 3.3.0.1 for IAP deployments.
The following are the setting/recommendations:
Device Vendor & Product ID
Provisioning for only 4G
Provisioning for 4G/3G
0x0f3d68aa/0x119968aa
usb_type=sierrausbnet (10) cellular_nw_preference=4g_only (3) usb_dev=0x11990fff
usb_type=sierrausbnet (10) cellular_nw_preference=auto (1) usb_dev=0x11990fff
I am trying to setup it in the RAP remote access point controlled by mobility controller mode.
And I am unable to access the rap's cli through ssh/telnet. Can you tell me how to configure it through the web gui ?
Please have a look at the following; Provisioning 4G Modems on Remote Access Points
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/Remote_AP/Support_for_4G_USB_Modem.htm?Highlight=usb
