I'm currently trying to get my RAP5WN work with an Huawei E170 3G from 3 (Austria) stick.
I tried with these settings but the RAP won't connect to the controller over the cellular link:
USB-Dev: 0x12d11003
Init: AT+CGDCONT=1,'IP','drei.at'
User: drei.at
PW: drei.at
Number: ATDT*99#
Has anyone experience with this setting?
Kind regards
Frequent Contributor I
Hi Ropo, If you can't connect modem to RAP devices, try disable the CD-Mode on the modem first.
Try to connect to modem using Hyper Terminal on serial port number where is connect the Huawei modem .
If you don't receive Ok after you send the AT command restart the computer (unplug the modem ) .
If you can't type the commands in the Hyper Terminal window copy command and paste to host .
Send the AT commands to modem even if you don't receive OK response .
This commands works but not in the same way for all types of Huawei modems .
AT^U2DIAG=0 --> is to disable CD
AT^U2DIAG=1 --> is to enable CD
Usually I only input these details on the RAP :
Device : any
Dial Str : ATDT*99#
Initial Str : AT+CGDCONT=1,'IP','APN-NAME'
PPP Username : *****
PPP Password : *****
Its the alternative ways when you can't find your device on the recommended modem list.
