Occasional Contributor I
RAP5WN using AT&T USB Connect Mercury ( C885)
Hi Guys,
Any one of you ever did implementation using RAP5WN with AT&T USB Connect Mercury ( C885)? I've tried and fullfil the usb parameter but can't up, I've refered to document as attached but can't find the message content for that device.
Everyone who's ever did it kindly share it to us here...
Thanks and appreciate your help.
Re: RAP5WN using AT&T USB Connect Mercury ( C885)
What version of Aruba OS are you running on your controller? Looking at the 6.1 CRG, it appears that no Modeswitch is necessary for the Mercury. I used to have a Mercury. As far as I can recall, I never needed to enter any modeswitch info.
Zach Jennings
