Occasional Contributor I
RAp3 to Seierra wireless air card 763s
HI
Trying to provistion a Rap3 with a USb Seirra wireless air card.
The Air card is on the telus canada network
Any one have any luck.
Willie
Aruba
Re: RAp3 to Seierra wireless air card 763s
I would recommend to open up the TAC case to check and help you to confirm if this comes under support list.
Thank you.
