Occasional Contributor I
RDP drops in Mobility Controller teunnel
Greetings,
We have an Aruba 650 controller and 5 RAP-2WG raps. They connect to the controller over a VPN and rdp traffic has been dropping, sessions are terminated. All other connections are fine. I do not see a specific service for rdp. What is the best way to allow rdp traffic over the tunnel?
Thanks!
Re: RDP drops in Mobility Controller teunnel
Is the tunnel created by the RAP, or there is another tunnel?
The tunnel is created by the Aruba650. If you need more detail, if you could point me to the webGUI configuration I will look it up. I am new to this device.
Thank you!
Are the clients connected wirelessly or wired to the RAP2?
The clients are wired to the RAP 2WG devices.
Maybe we need to stop propagation of wasteful broadcast traffic to the wired interface.  Here is what you do:
Go to Configuration> Network> IP.  Edit the VLAN that wired users on that RAP2wg are on.  Click on the checkbox next to Enable BCMC Optimization and click on apply.  See if you still have the issues.
Re: RDP drops in Mobility Controller tunnel
Thanks, I will give that a try and report back.
I did not find the BCMC optimization option. The screen shot of the IP conifg page is attached. The firmware is ArubaOS 5.0.4.1.
Unfortunately, it is only supported in ArubaOS 6.x and above...
If this model can go to 6, I will see about upgrading the controller, if our model can be upgraded.
