RED PWR LED on APIN215
We have a Cisco POE switch that we use for our Cisco Phones and when we hook up our APIN215 to that switch the PWR LED goes red.   To me it looks like it might be something up with the power ratings on the POE swtich.  We have a specific mini POE switch that we purchase for the APIN215 but we wanted to see if we could use the Cisco switch as well.
Does anyone have any thoughts on what might be happening?
Frequent Contributor I
Re: RED PWR LED on APIN215
If it's the same as the 225, the red LED means that it's still in it's initial power up stage:
http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Aruba-225-LED-Status/td-p/131415
I'd suggest hooking up to the serial console and see if anything useful shows up there.
