Contributor I
RFP specs for Aruba IAP!
Hi All,
I am looking for RFP related specs for Aruba Instant, which should give Aruba an advantage over other competitors. Please help.
Thanks.
Re: RFP specs for Aruba IAP!
are you a partner?
If yes, on the partner portal there is lots of good material for you.
If not, I suggest talking to your sales rep or SE to figure out the best way to position Aruba.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Contributor I
Hi thanks for your reply....yes we are a VAD for aruba...can you please provide me some links....thanks
do you have a partner account?
ACDX #420 | ACCA
Contributor I
yes
