RIM devices won't connect to WPA2-Enterprise network
This is driving me nuts.. I have a ticket open with RIM but they're taking forever. I was hoping someone here might be in the same boat:
I seem to have extreme amounts of difficulty getting blackberries and playbooks connected to my WPA2-Enterprise PEAP/MSCHAPv2 network.
- Other clients work fine: OS X, Windows All, iPhone, iPad, iPod etc
- Some (read: few) blackberries work
- all 9790 blackberries I've tried do not work
- Multiple playbooks do not work
Anyone experience something similar?
Dave
Re: RIM devices won't connect to WPA2-Enterprise network
Can you do show auth-tracebuf <mac of bberry client> while you are attempting to connect one and post the results back here?
Cheers
James
Sure. I'll have one in my possession this afternoon and will update.
Dave
Here is a log with a few attempts.
This is what radius says:
Thu Mar 8 13:39:01 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 13:41:39 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 13:44:26 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 13:47:47 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 13:49:05 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 13:59:43 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
Thu Mar 8 14:09:17 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
ps. .txt really should be a valid attachmet extension.
Dave
Each RIM device comes with a client manager where you have to load the CA certificate of the WLAN in order for it to connect.  It doesn't seem to just skip or accept any CA server unless you upload it to the device.  Maybe they have evolved recently.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi Colin,
I will try to do that and report back. It seems that only newer blackberries are problematic, which is strange.
Anyways, I will let you know how it goes.
Dave
daveald wrote:
Hi Colin,
Dave
Wow.  That does not make sense.  What is the "show auth-tracebuf mac <mac address of blackberry>" output?
Hi Colin,
There is a zip file up a few posts with a longer and properly spaced log. Here is an excerpt. This just repeats, and radius logs what I mentioned earlier...
Mar 8 14:11:14 eap-id-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 5
Mar 8 14:11:22 station-up * 80:60:07:21:27:13 d8:c7:c8:17:09:2a - - wpa2 aes
Mar 8 14:11:22 eap-id-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 5
Mar 8 14:11:22 eap-id-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 26 user1
Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 65532 210
Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65532 64
Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 7 6
Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 7 74
Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65521 276
Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65521 1090
Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 8 1024
Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 8 6
Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 113 208
Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 113 1086
Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 9 1020
Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 9 6
Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 5 208
Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 5 646
Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 584
Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 13
Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 108 215
Mar 8 14:11:22 rad-reject <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 108 44
Mar 8 14:11:22 eap-failure <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 4 server rejected
Mar 8 14:11:31 station-down * 80:60:07:21:27:13 d8:c7:c8:17:09:2a - -
It certainly is responding to the Radius Server's rejection...
Aruba
I use both a blackberry 9900 and playbook w/ v2.0 to connect to the Aruba corporate WPA2-Ent WLAN without any issues, as I recall it worked when I had it setup on a lab SSID as well.
| Adam Kennedy, Systems Engineer - adamk@hpe.com
| Service Providers – Aruba, an HPE Company
| Twitter: @adam8021x | Airheads: akennedy
