RMP not coming-up correctly
  • 1.  RMP not coming-up correctly
    Posted May 23, 2017 08:17 AM
    We're having a big challenge deploying Remote Mesh Portals. We had these systems working, in lab, with ArubaOS 6.4.3 beta - using AP-274 a year ago. Now we're ready to hang - the RMPs will not come-up correctly. MPs work fine.
    When provisioned as RMP:
       The RMP will use all IP addresses from a VPN Services/IPSec Address pool - the RMP steps through all available addresses in pool then start over from the pool. Plus, I can only re-provision the RMP after a purge from AP Console.
    Attached show:
    RMP online - incrementing IP address
    2 Children - they never appear
    Radios displaying EIRP/MaxEIRP - 0/0 - this is displayed directly after new IP address assignment. I cannot ping the assigned IP.
    The AP comes-up fine as a Remote AP.
    Tried RMP on AP-325,274,275,225.
    Any help is appreciated.
    Is it there a tool to compare config files? I would like to load an old config.
    ArubaOS - 6.5.1.5
    Controller - 7210
    Dummy VAP created with split-tunnel and VLAN
    Open TAC case #5318429414 28 Mar 2017
    Greg Crockett
  • 2.  RE: RMP not coming-up correctly
    Posted May 23, 2017 08:51 AM
    You should continue to work the case.  Very few people know about or even deploy remote mesh portal and the functionality could have been silently broken.
