Contributor I
Radio and ARM Profile Power Settings
Trying to figure out and understand power settings Radio profile advanced setting “Transmit EIRP” settings vs ARM profile settings “Max Tx EIRP and MIN Tx EIRP”
From my understanding is ARM profile settings if you specify should work but when I look at power settings it seems like the radio profile is also changing settings sometimes and then again there are times max power is always something different then specificed from the radio and ARM profiles.
Example:
Radio Profile Transmit EIRP = 15
ARM Profile Max Tx EIRP = 18
ARM Profile Min Tx EIRP = 9
11g Ch/EIRP/MaxEIRP
AP:HT:6/9/21
11a Ch/EIRP/MaxEIRP
AP:VHT:161/18/22
Why is the Max EIRP showing 21/22 and not 18? It always seem like the G radio takes the min tx and A takes the max tx when defined is there a reason for that?
Re: Radio and ARM Profile Power Settings
Transmit EIRP is used when you aren't uing ARM for power management.
Are you sure you're not using the same ARM profile? They're nested profiles so changing it in one place will change it in the other.
Tim Cappalli | Aruba Security
The MaxEIRP is the regulatory max allowed (based on AP type, country code, if there is an external antenna and how it was provisioned, etc.
AP:HT:6/9/21 - This AP is running on Channel 6 (HT20), at 9dB EIRP, and the regulatory max for this AP/radio is 21dB (so if you set the ARM for 30 and manually set it for 30, it will only go up to 21 anyway)
AP:VHT:161/18/22 - This AP is running on Ch161 (VHT20)m at 18dB EIRP, with a regulatory max for this AP/radio is 22dB, so even if you set the max EIRP (in ARM or static) to 30dB, it will only go up to 22dB.
So you have the AP profile set to 15 (default), but ARM is set to let the AP run between 9dB and 18dB EIRP. So the AP is within your ARM range. If you disabled ARM, the AP would drop to 15dB EIRP. And if you set ARM to disable and set the AP profile EIRP to 127, it would max out at 21dB on the 2.4GHz radio and 22dB on the 5Ghz radio.
In general, there are fewer 2.4Ghz channels (3 non-overlapping in US), which means there's far more ACI and CCI so the power range adjusts downward. On the 5Ghz side, there's FAR more channels, (esp if DFS is enabled) and as such there is FAR less ACI/CCI and the APs can run louder without interference.
Hope that helps.
Jerrod Howard
