Occasional Contributor I
Radios do not turn on in IAP205
I have 3 new IAP205 WAPs but the radios will not turn on the indicator lights will not broadcast
Re: Radios do not turn on in IAP205
Are you providing DHCP to that IAP?
Colin Joseph
Aruba Customer Engineering
I am providing DHCP. I just looked at the model number tags and found that 3 of 5 WAPs which do not turn on were shipped as AP205
Thank you for the reply. I believe I found the problem. I just checked the labels again more closely and see that all 5 WAPs are not IAP. all were ordered as IAP205 but only two IAP205 actually are shipped and 3 are AP205. I need to return the incorrect items.
Sent from eye mypad
