Radius issues
I always have the error on the "Network Policy Server" -> "" A RADIUS message with the Code field set to 2, Which is not valid, what field received on port 1812 from RADIUS client Networkcontroller_4 Valid values of the RADIUS code. are documented in RFC 2865. ""
please suggest any solutions
Re: Radius issues
According to this:  http://technet.microsoft.com/en-us/library/cc735325(v=ws.10).aspx
Make sure the NPS is not configured to require the message authenticator attibute.
Also, check and make sure the preshared key between the controller and NPS are correct.
If you have any further issues, you probably have to contact Microsoft for a proper explanation of that message.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
