Occasional Contributor I
Radius time out connxtion issue
Hi , I had a problem with a 3400 controller , the OS istalled is 5.0 and configured with a 802.1x witch works well with radius server on 2008R2.
When I upgraded the controller to version 6.4.0. the 802.1x doesen't work , the first thing I done is to test the radius server from the controller , (on diagnostic , AAA server section)
the message I got is "connexion time out" , when I rebooted the controller on the partition with AOS 5 all works fine.
Is there someone who had the same issue , what can be the reason of this.
Thanks a lot.
Re: Radius time out connxtion issue
Do you have termination enabled ?
Get Outlook for iOS
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Hi Victor , yes termination is enabled.
It is the same configuration on the AOS 5 and works fine.
It is best practice to do the termination on the RADIUS server and not on the controller .
You should either purchase/install a third party cert or use your internal PKI to generate/install one on your RADIUS server.
Of course if you do this all your wireless will need to access the new certificate.
Thank you
Victor Fabian
Thank you Victor for your reply , I must diagnose deeply at my client
but I dont unterstand why all is fine with the old AOS,
Is there somme parameters added on the new AOS wich must be configured for the radius server or server group ?
Thank you.
Please take a look at this article
https://community.arubanetworks.com/t5/Controller-Based-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Controllers/ta-p/275809
Get Outlook for iOS
Thank you
Victor Fabian
Hi Victor , thak you for the link , you mean that the upgrade causes a certificate revocation and we must recreate a new certificate ?
An other information that I missed , the controller is a master and tne backup is down , is there any impact if ther is only the master in production.
Other thing , the client connect to the ssid without certificate (certificate was created on the 2008 server).
Thanks for your help.
Hi Victor , i was at my client site for more dignostics and I noted that there is no certificate service role installed on his 2008R2 server and then no CA issued. Now Im sure that the installation of a CA and disabling termination will resolve their problem. my question is , is there any impact on their infrastructure like AD access or Exchange with installing the role and CA ?
the client is affraid by this idea.
Thanks a lot.
