Contributor I
Range of outdoor AP 275!
Hi All,
We are planing for wifi coverage on Roads in an very big IT park, so that users can access some inhouse application while moving inside their cars. These application will give them parking related information witin this IT park.
I am currently planing this on google map, and have placed AP at a distance of approx 170m from each other.i.e i am considering 275 to give a range of 160-170m in diameter. Please suggest if AP 275 will cover this much distance???Expected signal strength at client is around -70dbm!
Valued Contributor II
Re: Range of outdoor AP 275!
Hi Mohan,
though it is cable of covering more than 150 mtrs diameter, it is advised to seek the help for deployment from Aruba partner or SE of your area.
Please feel free if you any further support on this.
Venu Puduchery,
