Regular Contributor I
Raps with DMZ controller
Hi forum,
I am having a bit odd a mental block
I have a master controller with some tunnels to a DMZ controller. I want to terminate raps on the DMZ controller.
Anyone point me in the right direction for this kind of implementation?
Never been able to deploy raps I am missing something fundamental
Re: Raps with DMZ controller
That is a major design question.  We will need tons of more information about your infrastructure.  If you have never setup a RAP controller, you might want to do that independently to understand all the parts involved, before terminating it on a DMZ controller....
OK - I have got a aruba 620 for lab and using a AP-105 as a RAP
I just want to start basic then layer on extra features later.
Note: I have not done this before!
I got 2 vlans, both trusted.  an inside and and outside if you like.
I run the wizard for RAP and provision, and I browse into the RAP and it shows disconnected from the controller
I check datapath tables, I see some udp/4500 traffic, not much.
I see via the console plugged into the 105 - I know it sees the master ip configured right - and the IP address the AP gets is on the same subnet.
The AP never comes up, I even disable control plane security to let any AP register?!
Dont know how to debug this!
Stumped, completely.   I can only guess I am missing a massive fundamental thing here.  Any suggestions welcome!
Nik,
Did you:
- Create an IPSEC pool?
- What is the output of "show crypto ipsec sa" when the AP is trying to connect
- Make sure that the LMS-IP of the AP system profile in that AP group has no ip address?
- Control Plane Security has nothing to do with it.
Thanks for the pointers cj. I'll post up a configuration when I get into the office. I have done what you've said, which is reassuring so I guess I am having a bit of an idiot moment! Bear with me and thanks again!
One quick question: for the inner pool of addresses. Just to make sure I have not misunderstood the documentation: should this address block be part of a subnet which is part of a vlan which is configured as an ip interface on the controller?
The inner pool can be any range.  I normally choose 8.8.8.1 - 8.8.8.20 so I do not get confused.
Cool I'll set up a lab at work and at home and I'll get this working if it kills me :)
Nik,
Does your controller have a public ip address, as a management address, or are you using a firewall to do a 1:1 NAT to a public address?
my original lab everything was private and the AP was directly connected (i was worried ADP may have confused my config) as I do not have PoE on my home network.
I appreciate this was a nonsense of a setup, but I just wanted to prove things in priciple.
At work I'll set up this:  controller, inside private, usual 172.16.0.0/24 and outside public ip space
with a AP that'll get another subnet IP, again public.  I'll introduce NAT later.
BTW - do I need a IP on the Vlan interface for the IP pool in IPSEC?  Or is the inner pool a bit of a "formality"?
Thanks! :)
