Re: SNMP monitoring
my controller is configure as master-standby this works fine
i will enable snmp to solarwinds upon configuration i can only see the ip of the VRRP which is fine,
but i want to see the 2 hardware to be monitored. how to configure this setup to be able to monitor the 2 hardware, thanks
Re: SNMP monitoring
You will have to consult SolarWinds on how to do this.  Each device would need to be monitored by its own specific ip address, NOT the vrrp...
