Re-entering License Key Problem
Well, I did a "write erase all" and the license got wiped.
I am now re-entering the license but I am getting:
"License key for feature Policy Enforcement Firewall Module is not supported for ArubaOS"
I searched and there seem to be no problem with solution like this. What seem to be the problem?
I attached screenshots. Thank you.
Re: Re-entering License Key Problem
What version of ArubaOS is the controller on right now?     It looks like that might be for an old PEF license, not a PEF-NG (post 5.x).   If you log into the licensing portal; http://licensing.arubanetworks.com you should see a pre 5.x and post 5.x license for PEF/PEF-NG.
I think it is ver 6.1.x.x
Please see attached screenshot.
Does that mean I need to get a new post 5.x lic?
Thank you.
I login here  http://licensing.arubanetworks.com and got the post 5.0 license key.
Thank you.
