Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
Hi Guys,
Im getting a strange reboots (M3 + 6.3.1.8)
this is what i got in the log:
Anyone can say to me what might be the cause?
Re: Reboot Cause: Hard Watchdog reset (Intent:cause:register ee:ee:50) ? Anyone can explain.
Is there any syslog id associated with that message?  I can't seem to see anything in the 6.3 Syslog message guide that matches that.
If there is a crash file available on the controller, you should send this to TAC to investigate.  Really, any unexpected reboot should be investigated by the TAC guys.
ACCP, ACCX #817, ACMP, ACMX #294
Crashes do not have a syslog ID, because they are unexpected.  Please open a TAC case.
We are seeing the exact same error message repeat endlessly after an upgrade of our M3 controllers to v6.4.2.2. 2 of the 4 controllers in the same chassis came up fine, 2 are in this endless reboot loop.
We havv opened a TAC case. We are online with them now and have been for hours. We do not seem to be getting anywhere
If anyone has solved this issue or knows about a solution. Please chime in.
We are having the same error on our secondary controller in our HA pair. It's been rebooting itself at least once a day with that error. It did it again today and hasn't come back online yet. It's been down for over an hour now.
We are running 6.3.1.13 on an Aruba6000-US
That is definitely not a routine occurrence. Please open a TAC case asap.
Frequent Contributor I
Can I check with firmware has fixed this issue?
"If there's a will, there's a way."
