Moderator
Recent AOS Firmware Releases
This post outlines high level information about recent AOS firmware releases.  Hopefully it will aid you in determining what version you should be running and help delineate the differences between versions.
Info about new versions of AOS will be added to this post as they are released.  Subscribe to this post to be alerted when new versions of code are released.
Please contact Aruba Support before upgrading if you have any questions.  A valid support account is needed to access the firmware files and release notes.  The release notes are the definitive source of information about a release and should always be read before upgrading.
AOS 3.4.5.1 Released 1/24/2012
  • Comments:
    • Patch release that fixes 44 known issues/defects on the 3.4.5 code train and adds some VLAN pool assignment enhancements.
    • Releases notes:
    • Software can be downloaded from:
AOS 6.1.3.0 Released 2/2/2012
  • Comments:
    • Maintenance release that branches from the 6.1.2 code train and fixes 150+ known issues/defects and adds a few minor features.
    • Enhancements:
      • AP-93H and AP-104 support
      • IPv6 Router Advertisement support
      • Hybrid spectrum support on the AP-105
      • Support for heartbeats in L2 GRE tunnels
      • SCCP v17 support
      • VLAN Pool assignment updates
      • Enhanced VDI support
      • Verizon LTE UML290 4G modem support
      • 802.1x supplicant support on the AP
      • Release notes:
AOS 5.0.4.5 Released 2/23/2012
AOS 6.1.2.8 Released 2/28/2012
Moderator
Re: Recent AOS Firmware Releases
AOS 6.1.3.1 Released 3/14/2012
Comments:
    • Patch release that fixes ~40 known issues/defects in addition to all of the fixes in 6.1.2.8.
    • Release notes: 6.1.3.1 Release notes
    • Software can be downloaded from: 6.1.3.1 Firmware
Moderator
AOS 5.0.4.6 Released 4/18/2012
Comments:
Moderator
[ Edited ]
AOS 6.1.3.2 Released 5/29/2012
Comments
  • Large patch release with over 125 bugs fixed.  There were 3 enhancements to existing features including more granularity on the non-wifi interference immunity setting, cell size reduction and ARP filtering enhancements.
  • Release Notes: The release note format was updated based on feedback from AirHeads.  There is a new Issues Under Investigation section which includes issues that have been reported by customers and have not been reproduced or confirmed.  We have no reason to believe they are affecting other customers.   The bug descriptions were also updated heavily.  6.1.3.2 Release Notes
  • Software can be downloaded from: 6.1.3.2 Firmware
Moderator
AOS 6.1.3.3 Released 6/22/2012
Comments
AOS 5.0.4.7 Released 6/22/2012
Comments
Moderator
AOS 6.1.3.4 Released 7/30/2012
Comments:
Moderator
AOS 5.0.4.8 Released 9/10/2012
Comments:
AOS 5.0.4.9 Released 9/20/2012
Comments:
AOS 6.1.3.5 Released 10/8/2012
Comments:
  • Patch release that fixes ~50 defects.  There are also some wireless performance enhancements that result from minor tweaks in radio behavior.  The release note format has also undergone some revision to make them easier to use.  The upgrade chapter has been streamlined and simplified.
  • Release notes: 6.1.3.5 release notes
  • Firmware: 6.1.3.5 firmware
Moderator
AOS 6.1.3.4-AirGroup Released 10/10/12
Moderator
AOS 6.2.0.0 Released 12/5/12
  • Early deployment minor release that add support for the 72x0 series of controllers.  There are a few new features including controller capacity alerts, LLDP support for the APs and 3g/4g backhaul link monitoring.  It also includes some enhancements to spectrum analysis, Dashboard pages and setup wizard.  DFS support has been extended to the AP-92,AP-93,AP-93h,AP-105, AP-134 and AP-135.  There are also over 75 bug fixes included in the release.
  • Release notes: 6.2.0.0 Release notes
  • Firmware:6.2.0.0 Firmware
  • Caveats: Please reveiw the release notes before attempting to upgrade a 3200 or 651 controller.
Moderator
AOS 6.2.0.1 Released 12/28/2012
