Recommended AOS code for 651
We are getting ready to deploy a 651 Controller but I noticed that the latest 6.1.3.0 has some major caveats related to the 651 funcionality , and I was wondering what 6.1.x.x AOS code is more stable for the 651 controller.
Vic
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Re: Recommended AOS code for 651
According to the release notes - "An Aruba 651 controller is susceptible to continuous rebooting if its internal AP (radio) is configured in Air Monitor mode (am-mode).
Workaround:
Reconfigure the internal AP (radio) in Access Point mode (ap-mode). Alternatively, you may disable the radio if not needed."
Thank you
Victor Fabian
Just be careful, if you're using mode-aware ARM, that internal AP may turn into an AM and cause the 651 to reboot.
Aruba
I always / always recommend
1) a seperate AP group for the internal AP on the 651 controller from the other APs in the deployment .
Why?   That way the configuration of that internal AP is deterministic and you don't have to be careful/mindful of any settings that you meant to apply in the broader deployment.
2) never modify any profile that has the word 'default' in it... instead make 'new' profiles for all APs, and seperate profiles on the internal AP vs. non-internal APs.   That way you (again) avoid any 'whoops we just turned on/off something on the internal AP that we only meant for the other APs.
This approach has served me...and many others well...
