MVP
Recommended configuration practices for configuration and fine tuning of SNMP traps
There are around a total of 308 snmp traps defined on controller and over 270 of them are enabled(as part of default enabled traps).
However these are flooding the NMS.
Certain trap messages are definately helpful in providing a legitimate headsup, but appears there's still some fine tuning that could be performed on the traps that are enabled by default.
Is there any best configuration practice document for configuration of SNMP traps?
Re: Recommended configuration practices for configuration and fine tuning of SNMP traps
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=23728
Page 42
Colin Joseph
Aruba Customer Engineering
