Super Contributor I
Redundancy
Hi
Are there any restrictions to build a high availability with 7000 series controllers, as these can only be Local?
And if there are also restrictions to be server license?
Re: Redundancy
You can use 7000-series together as master-local, but a 7000 should never be
a master for 7200 series.
For example:
These are OK:
70x0 master, 70x0 local
These are not OK:
70x0 master, 70x0 local, 70x0 local
7030 master, 7200 local
Tim Cappalli | Aruba Security
Super Contributor I
Re: Redundancy
Hi TiM
Thanks for the help
