Regular Contributor I
Redundant Controller Master-StandbyMaster won´t sync the database
Hello communtiy,
we have 2 651 Controller, software 6.2.1.4 running on bouth.
So I configured Master redundancy with vrrp and the failover works (the same config on bouth controller, oher IP and hostname).
But the database sync won´t work.
Controller1 Master:
Controller2 Backup Master
Controller1:
Have anybody an idea why master redundancy is not configured?
Controller1
Controller2
Have anybody an idea why the database sync doesn´t work?
Why the controller says master redundancy is not configured?
Re: Redundant Controller Master-StandbyMaster won´t sync the database
On your backup, set the vrrp to have a lower priority.
vrrp 1
shut
priority 90
no shut
you have to set the peer ip address and make sure the ipsec keys match.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Ok, I ´ve done this.
But the sync does not work.
Now this message comes up:
try to do it from the master.  What is the output of 'show master-redundancy' on both boxes?
Ok, it still doesn´t work.
yes I tried it from the Master:
Master:
Backup:
you have the same peer-ip configured on the both boxes.
On the master, the peer should be the backup.
On the backup, the peer should be the master.
I changed it but it won´t work.
Master:
Backup:
Is the problem that the show master red
The two controller are vrrp id 1 state master ?
The log shows this:
The controllers cannot communicate with each other.  That means that the ipsec tunnel is not coming up.  Check your shared secret again, which must be the same on both boxes.
