Occasional Contributor I
Remainining AP licenses missing - Causes Reboot of APs
Hello together,
I have a master-local topology of two 7205 (master standby) and two Aruba 7030 (active local) controllers. Centralized licensing is used and I'm facing licensing issues, which cause many of my access points to reboot. I'm facing the issue since one week now and made no configuration changes.
All controllers are running with firmware 6.5.4.2.
Installed at my infrastructure are 150 AP Licenses, 139 of them are used by CAP access points. The problem is that the last 11 remaining licenses are not used and not shown at the licensing overview, which causes my access points to reboot.
All access points in a bootloop are configured to connect to the master and standby controllers via LMS settings.
Please look up my screenshot at the attachement.
Could someone give me a hint to fix the problem?
Thanks a lot and have a great day.
