It is possible to configure a LMS ip address to the RAPS?
For example let say i got a central site with 2 internet connection.
I would like to put the principal ip address and also the backup one which will be the other internet conection
It seems to work but when i reboot the Remote AP it doesnt goes up....
This configuration is not saved in the RAP if its rebooted?
IS the only way of doing this is by putting a DNS name? and setting one ip address as the primary when that does not respond then it will propagete the new ip address?
Cheers
Carlos
