Remote AP
I have a remote AP that was deployed and I want to make changes to it. Can I do this from the controller that it is connected to?
Re: Remote AP
Every remote AP gets its configuration when it boots up and contacts the controller.  Even after that, most changes made to that Remote AP's AP group while the AP is running get propagated real-time.
Colin Joseph
Aruba Customer Engineering
Re: Remote AP
If you have a single controller, yes. If you have multiple controllers, you'll need to make changes on the master.
Sent from Nine
Tim Cappalli | Aruba Security
