Remote IAP Deployment
Can someone please point me to instructions for how to configure remote access points?  Our main site is up and running with no issues on a 172.16.x.x network.  How would I configure the Virtual Controller for a remote site on a 192.168.1.0 network?  When I configure a VC for that network on the IAP, my main site VC goes down.  Thanks.
Re: Remote IAP Deployment
All access points in a cluster need to be on the same subnet.  If there is a different subnet in the network, those IAPs need a different cluster.
Colin Joseph
Aruba Customer Engineering
