Super Contributor II
Remote pcaps from Aruba APs to Airmagnet
Hi!
We´re evaluating Airmagnet wifi analyzer pro and can´t seem to find a way to utilize the remote pcap features in IAPs and controllers to feed the Airmagnet software running on a network connected laptop. We currently do this with Omnipeek which works great.
Do you guys know if it´s possible to do this with Airmagnet or are we limited to using adapters connected to the laptop?
Cheers,
Christoffer Jacobsson | Aranya AB
Aruba Partner Ambassador
Aruba: ACMX #537 ACCP | CWNP: CWNA CWDP CWSP CWAP
Moderator
Re: Remote pcaps from Aruba APs to Airmagnet
i dont believe arubas current code sends to air magnet all that correctly.... for decoding remote captures, wireshark can suffice
regards
-jeff
