Frequent Contributor II
Rename a Controller
What's the easiest way to rename a controller?
Re: Rename a Controller
Easiest is via the Wizard...(requires reboot)
Configuration -> Controller Wizard
Or slightly harder is via the CLI (no reboot)
#conf t
#hostname XXXX
#wr mem
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Did you take a look at the user guide?
http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Content/ArubaFrameStyles/Base_WLAN_Switch/Replacing_a_Controller.htm#Modify
MVP
conf t
hostname namehere
OR what do you want to achieve?
Koen (ACMX #351 | ACDX #547 | ACCP)
Thanks the CLI is best. I want to achieve naming consistency. We have 3 controllers each using a different naming convention.
Nathan Kuhl
Information Technology
Wyoming Seminary
570-270-2241
*** Please report all problems to the help desk: http://helpdesk.wyomingseminary.org***
