Frequent Contributor I
Renaming 3600 WLAN controller
Have a situation where existing master (as a back-up) and local (as a back-up) controllers were relocated from a back-up DC to another back-up DC. Would like to rename the hostname of said controllers to match the naming convention used in the new DC. Will changing the hostname of the controllers break any syncronization with the other controllers at the primary DC? Exising controllers use GRE tunnel for sharing of Virtual Routing Tables for redundancy purposes. Anything else besides cosmetics when changing hostname or are things that should be considered?
Tony Marques
Re: Renaming 3600 WLAN controller
Changing the name via the hostname parameter does not affect anything network or connectivity related.
As always thanks Colin!!!
