Repeater mode. Is it possible?
Hi
I currently have a wireless network (WPA2 PSK) on 5GHz based on the ISP routers build-in wireless. I like to know if it is possible to setup a Aruba 215 to use the current 5GHz wireless as a backhaul connection and repeat it on its 2,4GHz radio?
I have looked at "mesh" for the Aruba ap but it looks to like it will require another Aruba AP connected to my ISPs router by means of a cable.
Re: Repeater mode. Is it possible?
Unfortunately, that is not possible.
