d.p
Contributor I
Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
I had to restore the config via memory because the other box got fried.  No 1 of 2 SSID's aren't showing.  I have checked the virtual AP and the SSID itself and they are all enabled.  Whats strange is the other SSID applied to this AP group is showing.
Can someone help me out?
Re: Replaced 650 N controller and now 1 of 2 SSID's not broadcasting
Can you do a show profile-errors
And also do show ap essid
Thank you
Victor Fabian
Lead Mobility Architect @WEI
d.p
Contributor I
Yeah I don't see the other SSID there, only the one.
(Aruba650) #show profile-errors
Invalid Profiles
Profile Error
aaa authentication via auth-profile "default"
(Aruba650) #show ap essid
ESSID Summary
ESSID APs Clients VLAN(s) Encryption
CompanyGuest 6 3 2 Open
Num ESSID:1
(Aruba650) #
But if I show that wlan ssid-profile its there:
(Aruba650) # show wlan ssid-profile ComapnyN-ssid_prof
SSID Profile "InfobloxN-ssid_prof"
Parameter Value
SSID enable Enabled
ESSID CompanyN
Encryption wpa2-aes
DTIM Interval 1 beacon periods
If I look at that specific AP group it only shows the SSID not showing?
(Aruba650) #show ap config ap-group Burnaby
SSID enable Enabled Enabled wlan ssid-profile "CompanyN-ssid_prof"
ESSID InfobloxN InfobloxN wlan ssid-profile "CompanyN-ssid_prof"
Do you have a VLAN assigned to the VAP that exists in the controller ?
Thank you
Victor Fabian
d.p
Contributor I
You mean under Wireless > AP Configuration > Burnaby > Wireless LAN > VAP > ComapnyN-vap_prof?  Then yes I do, its the same vlan as the controller sits (vlan1).
Is the VAP enabled too ?
Thank you
Victor Fabian
d.p
Contributor I
Yes.    If it wasn't why would the other SSID be showing?  It is part of the same VAP.
Can you please share the config
Also have you tried using the same VLAN as the one that is working ?
I noticed that the SSID is a WPA2/AES make sure the the AAA profile has been assigned correctly under the VAP
Thank you
Victor Fabian
d.p
Contributor I
Victor
I fixed it, that SSID was set to bridge instead of tunnel.  Once I changed it to tunnel it started broadcasting.
Thanks for your help.
Nice!!!
Thank you
Victor Fabian
