Replacement Grounding hardware AP 270
  • 1.  Replacement Grounding hardware AP 270
    Posted Sep 09, 2016 11:24 AM
    I'm in the middle of an indoor/outdoor with a bunch of AP 277's.  I just found out today that all (or at least a good portion of) the grounding lugs and screws from the AP boxes have been thrown away.
    I've looked at a couple stores for a reasonable facsimile to the replace them with, but so far nothing has been quite right.
    Is there something similar to the HP parts depot for Aruba equipment where I might be able to purchase these without the APs?
    Bill
  • 2.  RE: Replacement Grounding hardware AP 270
    Posted Sep 09, 2016 11:49 AM
    M4-0.7cm is the grounding screw, any lug or c-clip that will fit on that post will work as the lug. Make sure to use stainless steel.
