Replacing 3400 for a 3600
We are replacing a 3400 controller for a 3600 controller.  Is there a best way to do this?  can I just copy over the config, turn off the 3400 and turn on the 3600?  I know that there are licensing issues, but from  a harware/software/config standpoint, is that really all I have to do?
Re: Replacing 3400 for a 3600
The best way is to do a flashbackup and restore it on the new one.
But here's a couple good threads :
http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Replacing-Master-M3-controller-with-a-3600-Controller/m-p/21944#M1103
http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/Best-Practice-for-replacing-a-master-controller/td-p/7290
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks! I will give that a try
