Frequent Contributor I
Report AP LAN Speed
We have APs connected to 100 Mb and 1 Gb ports. Looking at the AP Monitor screen shows the Input and Output capacity of an APs Enet0 interface. Is there a way to report this on all APs? We need to upgrade some switches and this information would be most useful. I've looked at creating a custom report, but I don't see this level of detail.
Robert
Moderator
Re: Report AP LAN Speed
The closest that's currently present for this is the Port Usage Report.  Though this report focuses on the switch ports, which means it's an indirect way of getting the data you're looking for depending on if you have the edge switches monitored in AMP.  It would be worthwhile to file a feature request through the Ideas Portal on the support site to expand this report to cover ports on APs.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Thanks for your response. I'll post a feature request.
