Contributor I
Reports and triggers
I have a alert trigger setup to e-mail me when the high watermark the number of clients associated to an AP is reached.  Is there any way to get this in a report?  I would like to do a weekly or monthly report.
Moderator
Re: Reports and triggers
Try looking at the Device Summary report.  If you use a custom report struction, it's under Device Summary -> 'Most Utilized by Maximum Concurrent Clients' portion.  This option has a customizable entry for 'Number of items to include in device summary' which can be changed to fit the number of devices on your AMP.  Give it a try and let me know if this is what you were looking for.
Note that it includes all devices on your AMP, so if you're just looking for the AP results, that would be something worth filing into the Ideas Portal on the support website.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor I
Thanks, Rob.  I'm only looking for clients per AP.  I've tried the device summary but it's not what I'm looking for.  I'll submit it to the idea portal.
