Regular Contributor I
Reports
I would like to create a daily report that displays all the clients connected for the last day. What do I need to use in my report, Client Inventory, Client Session or New Clients ?
Dimitri
Re: Reports
Client Session Summary
OR
Session Data by SSID
BOTH WILL GIVE U NUMBERS OF CLIENTS  SUM (JUST DONT FORGET TO SET THE REPORTS for 24 hours and daily
Re: Reports
Thanks but what I would like is the detail about the clients like Client Inventory but only for one day (actually it displays all the clients).
Re: Reports
Create a new report definition with the "Client Session" type and then select the details you want in the report. For time frame do "Start: 24 hours ago" and "End: now". Schedule the report to run at midnight.
Tim Cappalli | Aruba Security
Moderator
Re: Reports
Instead of doing 24 hours ago, you can also do time range of "yesterday" to "now".
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Re: Reports
Thanks, it's working fine with Session Data by Client and yesterday to now.
Regards
Dimitri
