Frequent Contributor I
Reset Bootstrap counters
Hi All,
anyone has any idea how to reset the bootstrap counters on the controller ? through a command or SNMP maybe ?
Re: Reset Bootstrap counters
The only option available to clear those counters is to reboot the controller
Thank you
Victor Fabian
Lead Mobility Architect @WEI
