Occasional Contributor I
Resources for 3G connections to RAPs
Are there any manuals etc available to read up on using 3G in liu of a wired connection on RAPs?  I have an individual whom is using several RAPs whom would rather use 3G modem than a wired connection.  I'm new to this so I don't know the downfalls etc of doing this.Any help would be great!
THX!
Re: Resources for 3G connections to RAPs
i know the first thing u need to do is have your controller in the 6.0.x version of code to have the options avaiabe to you..
i have a few loactions running over 4g verizon cards and they do work very well.
THX!
Please try the Remote Access Point Validated Reference Design on the page here http://www.arubanetworks.com/technology/reference-design-guides/ will give you information.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
