Right power
When building  a high density deplyment  , what is the right power to choose for 2.4 and 5 ghz
Some site survey tool says  for 2,4 ghz choose 3dBm
and for 5 ghz choose 16dBm
And some other vendor says choose 8 dB to support  worst client (11 dBm)
So what aruba says  ?
Re: Right power
Did you already do a physical site survey?
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Right power
Hi CJ,
Not yet.
Re: Right power
You should take a look at the 802.11ac VRD here:  http://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-802-11ac-Networks/ta-p/242637
