Roaming with Clearpass and Ruckus and Aruba
  • 1.  Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 04, 2018 04:30 PM
    you have a Ruckus WLAN and an Aruba Wlan and Clearpass. The customer will use both WLAN Systems. He will have that the client didn´t lost the connection if a user roams from Aruba do ruckus.
    What I mean if he connect to ruckus and move to Aruba he will not that the client reconnect. He will use Clearpass for both systems
    and ideas
  • 2.  RE: Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 04, 2018 04:45 PM
    and ideas
    Using the Event Tracker in ClearPass, you should see the authentication event when the client devices attempts to reconnect. What is the response from ClearPass, or the error message that prevents ClearPass from authenticating the user? Is the same SSID configured on both systems?
  • 3.  RE: Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 24, 2018 10:11 PM
    Roaming from ruckus AP to Aruba AP is not supported.
    This is because each system is not interlocked. Even if the SSID is set the same, the clients will reconnect when they move (in the RF range of each other).
    In the clear pass, it is possible to confirm that the user repeats the connection and repeats the connection.
    Of course, it can be confirmed by bssid information of AP in client access information.
  • 4.  RE: Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 25, 2018 05:10 PM
    Hi
    Roaming it not possible. The client will have to reconnect. If the reconnection is fast, the client might not notice it.
    Hope it helps
  • 5.  RE: Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 25, 2018 09:33 PM
    In the current configuration, roaming is not possible.
  • 6.  RE: Roaming with Clearpass and Ruckus and Aruba
    Posted Jun 25, 2018 10:17 PM
    A single model should be configured.
    Because they are each system, they do not work together.
