Rogue, suspected rogue, neighbor, valid and so on
Hi guys,
If I check in the RAPIDS tab in AirWave I can see a lot of rogue APs, suspected rogues, suspected neighbors and so on, based on the default rules configured in AirWave. However, all these are customer legitimate APs from other vendors that are installed around the campus, so I can ignore them. And I think this happens in most cases. Do you know some practical cases or examples where this classification of APs have to be taken into account?
Julián
Re: Rogue, suspected rogue, neighbor, valid and so on
Have you read the chapter "Using RAPIDS and Rogue Classification" in the Airwave documentation?  If not, please do, because it will give you an explanation of the purpose of the airwave rules...
HI Colin,
I have similar issue on this ticket. I have not idea what is Rogue mean ? and how how do we fix it and
Will if effect our user experiecen
Borey,
It could mean different things, depending on how it is used.  By default, nothing is done.  Did you read the Airwave Chapter on IDS in the documentation?
Can you provide the document link?
Borey Chum
Managing Director
Luxury Machine Co., Ltd.
#616, St. Tepvong, Mondoul II Village,
Svay Dangkom, Siem Reap,
Kingdom of Cambodia
Tel/Fax: (855-63) 969 877
www.luxurymachine.com
Home> Documentation> Rapids on the Airwave Server.  By default, all observed foreign WLANs are recorded in the Rogue number.  You can set rules to change that.  If you do nothing, it will not affect your network.
