Contributor II
Role Mapping - Smart Devices
Within CPPM, is there a way to define a role mapping for all smartdevices (Andriod, iOS, Blackberry)? I try the following an it's not working.
Re: Role Mapping - Smart Devices
Authorization:[Endpoints Repository] Category EQUAL Smartdevice
Tim Cappalli | Aruba Security
Contributor II
I can only set it like this and it still not working..
Contributor II
OK...i got the setting per your suggesting and it's till not working...
If you lookup the device in the endpoint repository, is it profiled?
Contributor II
Profile is "No".
Do you have DHCP relays configured pointing to ClearPass?
Contributor II
No. Not sure where to do that at. Our DHCP are handle by the domain controller.
Wherever your layer 3 interfaces live for the clients, you need to add DHCP relays pointing to the ClearPass servers.
Contributor II
We have the DHCP relay point to our DHCP server currently. If I were to change that to Clearpass would that break DHCP to my Domain controller who is handling out the IP? How is that suppose to fix DeviceFinger printing of SmartDevices?
