Dear All,
I have been tested like below topology, but can not make it works.
So, I need help from all of you.
First, I try to use OSPF Protocol for Air Mesh Link between AP-A and AP-B. It's not working.
Is it normal? I mean that we can not use OSPF protocol between WiFi Mesh link with MSR-2000 Series.
Second. I try to use AWR Protocol for Air Mesh Link between AP-A and AP-b. It's works.
And then SW-A and AP-A, SW-B and AP-B have OSPF Protocol for routing exchange. It's works.
For exchanging all network route, I try to redistribute routes between OSPF and AWR Protocol. it's not work.
I found that,
Redistribution from AWR to OSPF is working, have command on "router ospf".
Redistribution from OSPF to AWR is not working, have no command on "router awr".
is it normal on MSR-2000 that have no functionality of redistribution from OSPF to AWR?
If it is normal, how can I routing above topology? tell me best practise for me.
Moon-Kee Bahk.
