Occasional Contributor I
S2500 Flow Control on 10GbE ports
Is it possible to enable flow control on the 10GbE ports of an S2500?  I've created an enet-link-profile setting flowcontrol to on and assigned to port, however, the show interface command shows that flow control is still disabled.  Assigning the same profile to a 1 gig port seems to work fine.
Contributor II
Re: S2500 Flow Control on 10GbE ports
Can you dump o/p  for
 "show interface-profile enet-link-profile  <your-profile-name>"
"show running-config interface gigabitethernet <uplink-intf>"
 "show running-config interface gigabitethernet <uplink-intf> | include flowcontrol
  ex: show running-config interface gigabitethernet 0/1/2 | include flowcontrol
#show interface-profile enet-link-profile "EqualLogic-Enet-Profile"
Ethernet Link "EqualLogic-Enet-Profile"
Parameter Value
Speed auto
Duplex auto
Autonegotiation Enabled
Flowcontrol on
#show running-config interface gigabitethernet "0/1/1"
interface-config gigabitethernet "0/1/1" detail
interface-profile mstp-profile default
point-to-point Disabled
portfast Disabled trunk Disabled
rootguard Disabled
loopguard Disabled
bpduguard Disabled auto-recovery-time 0
interface-profile pvst-port-profile default
rootguard Disabled
loopguard Disabled
interface-profile lldp-profile lldp-factory-initial
lldp transmit Enabled
lldp receive Enabled
lldp tlv-select port-description Enabled
lldp tlv-select system-name Enabled
lldp tlv-select system-description Enabled
lldp tlv-select system-capabilities Enabled
lldp tlv-select management-address Enabled
lldp tlv-select port-vlan-id Enabled
lldp tlv-select vlan-name Enabled
lldp tlv-select aggregation-status Enabled
lldp tlv-select mac-phy-config Enabled
lldp tlv-select max-frame-size Enabled
lldp tlv-select power-management Enabled
lldp med-tlv-select network-policy Enabled
lldp med-tlv-select power-management Enabled
lldp transmit-interval 30
lldp transmit-hold 4
lldp fast-transmit-interval 1
lldp fast-transmit-counter 4
med enable Enabled
proprietary-neighbor-discovery Disabled
interface-profile poe-profile poe-factory-initial
enable Enabled
poe-maxpower 30000
poe-priority low
interface-profile enet-link-profile EqualLogic-Enet-Profile
speed auto
duplex auto
autonegotiation Enabled
flowcontrol on
interface-profile switching-profile EqualLogic10GbE
switchport-mode access
access-vlan 30
native-vlan 30
storm-control-broadcast Enabled
storm-control-multicast Disabled
storm-control-unknown-unicast Enabled
storm-control-bandwidth 50
trunk allowed vlan 30
mtu 9216
qos trust aruba-device
description SAN0
trusted port
igmp-snooping mrouter-vlan 0
mld-snooping mrouter-vlan 0
#show running-config interface gigabitethernet "0/1/1" | include flowcontrol
<blank>
The following also indicates flow control is off, correct?
#show interface gigabitethernet "0/1/1"
GE0/1/1 is administratively Up, Link is Up, Line protocol is Up
Hardware is Gigabit Ethernet, Interface is SAN0, Address is 00:0b:86:8d:45:b3
Encapsulation ARPA, Loopback not set
Configured: duplex (Full), Speed (10 Gbps), FC (Off), Autoneg (Off)
Interface index: 130
MTU 9216 bytes
Link flaps: 0
Flags: Access, Trusted
Link status last changed: 0d 04:15:04 ago
Last update of counters: 0d 00:00:02 ago
Last clearing of counters: 0d 07:48:54 ago
Statistics:
Received 13797292 frames, 78670244604 octets
37 pps, 31.788 Kbps
13796720 unicast, 515 multicast, 57 broadcast
0 runts, 0 giants, 0 throttles
0 error octets, 0 CRC frames
Transmitted 10908549 frames, 20251037718 octets
43 pps, 1.502 Mbps
10908032 unicast, 513 multicast, 4 broadcast
0 throttles, 0 errors octets, 0 deferred
0 collisions, 0 late collisions
Interface is not PoE capable
Thanks!
Aruba
[ Edited ]
Boomboom21,
I suspect in your system log you have the following error:
Apr 6 14:42:26 :335311:  <WARN> |ChassisManager|  Configuration parameters under enet profile (EqualLogic-Enet-Profile) does not match for interface GE0/1/1, Ignoring the configuration
Try the following enet-link-profile instead:
interface-profile enet-link-profile "10GE-FLOW"
   speed 10000
   duplex full
   flowcontrol on
The reason is that the system is trying to apply "speed auto" and "duplex auto" when a 10G interface can only be speed 10000 and duplex full. If you apply the above profile instead, you should get the following:
(ArubaS2500-48P-US) (config) #show interface gigabitethernet 0/1/0
GE0/1/0 is administratively Up, Link is Up, Line protocol is Up
Hardware is Gigabit Ethernet, Interface is GE0/1/0, Address is 00:1a:1e:0a:23:f2
Configured: duplex (Full), Speed (10 Gbps), FC (On), Autoneg (On)
Negotiated: duplex (Full), Speed (10 Gbps)
Best regards,
Madani
That did it!  Thank you!
