Gus
S2500 Uplink Questions
I am trying to get clarification on if it is possible, instead of using the fiber ports on the S2500 as an uplink to a 650, we can use Ethernet ports to connect the two devices.
Aruba
Re: S2500 Uplink Questions
Gus,
The base ports (copper) have the same functionality as the uplink ports, stacking capability aside, so there shouldn't be an issue connecting them to the 650.
Gus
Madjali,
Thank you, one would think so but needed a confirmed answer. Have a wonderful evening
