SNMP Poll for SiteSurvey kind of output
           Is there a way to get the list of all the APs visible in the air from the controller via SNMP Polling (Similar to Site Survey output). The list should include the APs not managed by the controller. If available will need the OID for the same.
Tuhin
Re: SNMP Poll for SiteSurvey kind of output
Would this help ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thanks Victor.
Frequent Contributor I
Hi Victor, what document did you get that screenshot from?
Marcelo Lew
Wireless Network Architect-Engineer
University of Denver
