SNMP Traps simple question
  • 1.  SNMP Traps simple question
    Posted Nov 15, 2012 10:08 AM
    Is there a cli command on the M3s to disable many traps at once?  I only need a few enabled, but seems you would have to disable the ones you don't need one by one.
    Thanks!
  • 2.  RE: SNMP Traps simple question
    Posted Nov 15, 2012 10:12 AM
    I see a post below that Cjoseph posted a script to disable all at once (by doing it one by one), I'll use that for now.  However, a command to disable "all" (without turning SNMP Traps off) would be nice..
    Thanks Cjoseph,
    Marcelo
